It is currently Wed May 06, 2015 9:49 am
 Post subject: Hyper links in Outlook
PostPosted: Mon Jul 19, 2004 11:58 am
Can I set up my Outlook to open embedded hyperlinks in incoming e-mail messages to Opera instead of Internet Explorer ?
PostPosted: Mon Aug 16, 2004 3:18 pm
King of All Voodoo2 Cards
I was under the impression that simply making Opera your default browser would do this, unless I'm mistaken.
 Post subject: Re: Hyper links in Outlook
PostPosted: Mon Aug 16, 2004 5:43 pm
If you set your default browser to Opera, all your links in Outlook will open in Opera.
PostPosted: Mon Aug 16, 2004 6:35 pm
Yes...this is a default browser issue.
...and no, you can not specify just opera and use iE everywhere else.
PostPosted: Tue Aug 17, 2004 6:20 pm
Thank You very much !
I was looking for an option in Outlook I needed to change. I switched Opera to the default browser and it works perfectly.
Thanks again,
Mike
