It is currently Tue Jan 27, 2015 2:29 am
 Post subject: Google Voice?
PostPosted: Sat Oct 31, 2009 10:40 am
Anyone using Google Voice? I'm very curious about it, and I finally got an invite. I also see that I can port my cell phone's vm to it.
Will I have the option to revert to my old voicemail if I don't like it? I'm curious about people's experiences w/ google voice. Thanks.
PostPosted: Wed Dec 02, 2009 4:49 pm
I currently use google voice for my business line. Not sure if this will help but I will point out a few thing that I like and don't like.
Pros:
Keeps personal calls separate from business calls
Can either display number calling or google voice number (so far this has helped tremendously to keep my minutes down since I just added it to my circle)
Allowed me to get rid of vonage
send sms messages as well as calls
Transcribes voicemails and texts them to me
Cons:
no good program for my windows mobile phone to use with google voice so I just have to use internet explorer, not the fastest method
No pc phone, like skype (not sure if i would use it but would like the option)
not really accurate with the transcipts
i don't use the google vm on my phone. I hate checking voicemails and since it texts me I just use the google vm.
Hope this helps
Bobby
PostPosted: Wed Dec 16, 2009 9:41 am
I like the fact that it can ring both my cell and home phone when I get a call. Also, if I'm on the computer, I can do my texting there instead of with the phone.
All my calls and texts are also logged on the cloud, so I don't lose them with a phone wipe.
One thing I don't like is that the text doesn't come instantly to my phone. The best you can do is set it to refresh every 5 minutes to check for new messages. If you opt to forward it to your cell #, you get them instantly, but I'm not a fan of the workaround.
