It is currently Sun Apr 26, 2015 1:57 am
 Post subject: Android 1.5-Cupcake
PostPosted: Fri May 29, 2009 7:01 am
Well now with the US finally getting the OTA update, what are people thinking about it? I get fed up with waiting and updated last night manually from this site, http://www.androidcentral.com/how-manually-install-android-15-cupcake-without-rooting-your-device
I love it so far, a lot of nice eye candy, and runs smoother. This would have helped a lot if this OS version was released at the start of Android.
PostPosted: Mon Jun 29, 2009 12:57 pm
I like it, except that it erased one of my preloaded wallpapers. Yes, I know I can d/l whatever wallpaper I want, but it's the principle of the matter.
PostPosted: Mon Jun 29, 2009 3:15 pm
Can we download android yet? i wanna dualboot that with win7 on my netbook
PostPosted: Thu Jul 16, 2009 10:31 am
Here: http://code.google.com/p/live-android/
Figure out how to copy it to your Hard drive or SSD
PostPosted: Thu Jul 16, 2009 10:38 am
Wicked! Thanks!
PostPosted: Fri Jul 17, 2009 7:47 am
TravBv2.0
TravBv2.0
Don't you have to have some sort of emulator to run Android on your desktop? Android on x86 is very, very alpha right now. Seeing as to how mobile phones are running ARM processors, I'd think you'd need an ARM emulator.
PostPosted: Fri Jul 17, 2009 8:30 am
Runs fine on virtualbox from sun.
PostPosted: Fri Jul 17, 2009 9:47 am
Oh yeah? i installed that on my machine a little while ago, but i dont have any OSes i care enough about to drop in there. Looks lik Android is the one! just a question, when you're installing it in virtual box, what OS do you tell it that you're installing? i dont recall seeing andriod in there
PostPosted: Fri Jul 17, 2009 12:34 pm
Select Linux as the Operating System and Other Linux as the version. It works fine! No need to change settings.
PostPosted: Fri Jul 17, 2009 1:44 pm
Wicked! im downloading Android right now, and i'm going to do that.
*Sigh* torrents are amazing but my stupid ISP knocks my speeds down to dial up if i use them. and look! this is a perfectly legal reason!
I'm wickedly excited to try this out!
EDIT: i read the install files on LiveAndroid v0.2, and its x86 compatible!
