It is currently Mon Jan 26, 2015 10:05 pm
 Post subject: Mega laptop cooler spotted at sears!
PostPosted: Fri Jan 23, 2009 6:22 pm
Desperate attempt to run crysis
:shock:
PostPosted: Fri Jan 23, 2009 6:28 pm
Million Club 2+ [PC]*
That reminds me of an expensive lesson I learned in Iraq trying to cool my Dell laptop. Did the same thing you're doing. It was 135°F in the room I was in and the laptop kept overheating every time I'd try to rip a CD or DVD. So I used the fan. First, my hard drive went out. Replaced that, then my Ram and mobo burned up. Turns out the vibration from the fan unlocked the ram and when it slid out while the laptop was on, it fried the ram and ram socket on the mobo.
PostPosted: Fri Jan 23, 2009 9:11 pm
Team Creamsicles
Team Creamsicles
Don't be a pansy. Mod your own notebook cooler!
http://forum.notebookreview.com/showthread.php?t=344810
PostPosted: Sat Jan 24, 2009 4:50 pm
Yeah, it works wonders. The thing is that the fan's structure must be durable. If you sit a laptop on a flimsy box fan, the laptop's weight might bear down into the fan's grills, causing slower fan speed and questionable circulation.
For my cooler, I would put the box fan behind the lid of my notebook. If I put the lid at a certain angle, the air can draw down the lid and go beneath. I was able to keep my notebook about 15 to 25 degrees cooler after that.
