It is currently Mon Jan 26, 2015 3:50 am
 Post subject: Is there anything good for the express card format?
PostPosted: Sun Dec 28, 2008 2:03 pm
I was looking on Newegg and all I could find was adapters for USB, FireWire and things like that.
PostPosted: Thu Jan 01, 2009 6:15 am
I'm a little confused by your post but I will try to help :D
Did you mean "type of" express card (PCMCIA)? Are you looking for something specific?
All of these have potential to be "good" given the right situation.
pcmcia.org wrote:
PC Card Applications
The PC Card Standard is very flexible, allowing the integration of an enormous variety of peripheral devices. Some of the applications which have been developed throughout the years of the existence of the PC Card Standard:
* 10/100 Mbps Ethernet Adapters
* A/D Converters and other Data Acquisition Devices
* AM/FM Radio Tuner
* Biometrics cards (Fingerprint reader)
* Bluetooth cards
* CD-ROM Interface
* Cellular Phone Interface (WAN)
* Digital Camera
* Docking Station Interface
* Ethernet LAN Adapters
* GPS (Global Positioning System) Cards
* Hard Drives (Rotating)
* Infrared Wireless LAN Adapters
* ISDN Cards
* Joystick Interface Cards
* Memory Cards - Flash, SRAM, and many others
* Memory Cards Adapters - SD, , MMC, SmartMedia, CompactFlash, MemoryStick, etc.
* Modem/Ethernet Combination Cards
* Modem Cards
* Parallel Port Interface
* PDA PC Card
* Radio LAN Adapters
* SCSI Adapters
* Security Tokens
* Serial Port Interface
* SmartCard Readers
* Sound Cards, Input and Output
* Token Ring LAN Adapter Cards
* TV Tuner
* VGA
* Video Capture/Frame Grabber Cards
* Video Teleconferencing Cards
http://www.pcmcia.org/pccard.htm#appl
The FAQshave a lot of good info too.
 Post subject: Re: Is there anything good for the express card format?
PostPosted: Fri Jan 02, 2009 6:57 am
I use my ExpressCard slots mostly for my eSATA/RAID card. This is much faster then USB2 for large data transfers.
PostPosted: Fri Jan 02, 2009 1:04 pm
King of All Voodoo2 Cards
ExpressCard is not the same as PCMCIA or PC Card (CardBus)
That list only applies to the older 16-bit PCMCIA and 32-bit Cardbus adapters.
If you look at the page you linked to in your post, you'll notice that the last revision to the standard was 2001.
PostPosted: Fri Jan 02, 2009 4:40 pm
>>>ExpressCard is not the same as PCMCIA or PC Card (CardBus)<<<
Exactly. It's basically external PCIe.
PostPosted: Sun Jan 04, 2009 9:51 am
Firewire 800
Sata
SSD's (Apparently)
Wifi
TV Tuners
Memory card readers, possibly memory cards soon aswell
External Graphics cards (Asus XG Station is the only one I know of)
Probably more but thats what I know of
Express card is supposed to be the replacement for the PC Card platform. it is however developed by the same company PCMCIA (Personal Computer Memory Card International Association)
Express card 2.0 (release: Second half of 2008 - early 2009) complies with PCIe 2.0
