It is currently Mon May 20, 2013 4:33 am
 Post subject: MicroSD card won't work....
PostPosted: Fri Oct 10, 2008 5:29 am
TravBv2.0
TravBv2.0
I thought this would be a no-brainer, especially since I've been working with computers for nearly 6 years straight now.
Shortly after I bought a new cell phone, I bought a 4Gb MicroSD card to go with it. It came with a MicroSD to SD adapter. I plugged it into my girlfriends computer and it wouldn't recognize it. It gave a I/O error, seemed to freeze for a second, and then the system returned to it's normal state. I tried rebooting, but the computer took nearly 10 minutes to reboot, only to freeze right before the Windows XP login screen.
I thought it was just my lady's computer acting up. So I found a MicroSD to USB adapter in my box-O-computer stuff, and used that to try it on my machine. I got the same error from my PC and I know my rig doesn't have any problems. The weird thing is, I know the card is fine because I can load a program on the card using my phone's USB sync cable, but I can't actually load any files, PDFs or MP3s... and it's starting to piss me off.
Can anyone help me figure this issue out? Thank you for your time.
-Andrew
PostPosted: Fri Oct 10, 2008 11:33 am
What is the card formatted in...fat32, fat16...Ntfs? If the phone uses Linux then it is probably ext3 and windows can't read that.
PostPosted: Sat Oct 11, 2008 11:07 am
TravBv2.0
TravBv2.0
You know what? when you mentioned formatting the card, I remember I let the phone format the card. Anyone know what format Palm uses? It's a Palm Centro.
PostPosted: Sat Oct 11, 2008 11:43 am
Found the format type:
3GPP2 format
Try to format it in fat32 or ntfs then see if it works with the phone and pc.
I don't know if it will make the memory unusable with the phone or not.
PostPosted: Tue Oct 14, 2008 7:42 pm
King of All Voodoo2 Cards
4GB is a problematic size for SD cards.
http://en.wikipedia.org/wiki/Secure_Dig ... rger_cards
