It is currently Wed Jan 28, 2015 9:45 am
 Post subject: upgrade the drive, mirror the content?
PostPosted: Thu Aug 07, 2008 12:26 pm
Team Member Top 250
Team Member Top 250
I have a Dell m1210. Good for my needs but i'm planing to upgrade the HDD soon. Its runs Vista Primium Home and i'm just wondering if theirs a painless way to get say a 160 HDD to replace the internal 80 and clone the partitions, drivers, data, etc to the one 160 (though obviously with larger partition sizes) before swaping out the HDDS so when i put that 160 in everything is where it should be.
PostPosted: Fri Aug 08, 2008 4:19 am
Team Dino
Team Dino
Still my favorite option if you're looking to buy.
It will even correct your boot configuration if you move from pATA to sATA!
They have a download version as well, but for some weird reason it's $3 more right now.
n0b0dykn0ws
PostPosted: Fri Aug 08, 2008 5:08 am
I downloaded it from newegg & I couldn't activate it due to no serial #.
Newegg gave me a refund immediately.
I would get the cd if I were you.
PostPosted: Fri Aug 08, 2008 6:13 am
Team Member Top 250
Team Member Top 250
n0b0dykn0ws
so how would that work if the new drive is outside the case ho wouldi power it on and the laptop to mirror the content?
PostPosted: Sat Aug 09, 2008 3:52 am
Team Dino
Team Dino
Sorry. Meant to post that.
That's the one catch. You'll need an external enclosure.
n0b0dykn0ws
Team Dino
Team Dino
Really?
I got my e-mail with the serial number no problem.
And yes, I bought my digital copy through Newegg.
n0b0dykn0ws
PostPosted: Sat Aug 09, 2008 7:02 am
Team Member Top 250
Team Member Top 250
n0b0dykn0ws
thats not to hard to get, but can any of them fit a laptop HDD? includingthe interface to connect it to the Laptop
PostPosted: Sat Aug 09, 2008 6:47 pm
Team Dino
Team Dino
Oh yeah.
I have a enclosure for 2.5" HDDs. Supports sATA internally, and e-sATA plus USB 2.0 externally.
Comes with a power cable for when running on one USB jack or e-sATA.
Newegg doesn't carry it anymore though, so I can't point it out.
However, this will still work using USB 2.0. It will just take longer.
Then you can use the smaller HDD as portable storage space. :D
n0b0dykn0ws
