It is currently Tue Mar 03, 2015 7:30 pm
 Post subject: Memory problem on HP dv9000
PostPosted: Tue Mar 25, 2008 2:04 pm
Hi, I have a dv9000 that came with 2 512 memory modules (2 slots on the board) so I bought 2 1gig modules and swapped them both out.
Vista still only see 1gig of ram. I tried getting into the bios to look around but it looks like a stripped down bios for dummies.
Any suggestions? Thanks!
PostPosted: Tue Mar 25, 2008 5:46 pm
King of All Voodoo2 Cards
I think the first question would be is can the DV9000 actually support 2GB of RAM?
Check your owner's manual.
PostPosted: Mon Mar 31, 2008 9:11 am
All current HP's should support at the very least 2gb if not 4. Try re-seating the memory, if that doesn't work run memtest.
PostPosted: Tue Apr 29, 2008 2:23 pm
Yea, the older dv9000t's support up to 2 GB with the newer Santa Clara versions supporting up to 4 GB.
PostPosted: Tue May 13, 2008 7:45 pm
If you tried putting a 1GB stick in the first bank and then a 512 in the other, would your PC at least read 1.5GB? I'm sure that's better than one whole GB, especially if the BIOS can't recognize it. My next concern: was the BIOS updated to its latest version? Perhaps that might help a little?
