It is currently Sat Jan 31, 2015 12:45 am
 Post subject: Decent laptop for $800
PostPosted: Thu Mar 13, 2008 11:08 am
Hey all,
I need a recommendation for a reliable laptop for around $800 or so. I have been looking around (mostly finding some at Dell) but it is always nice to get suggestions from others.
I am on the brink of getting hired either at a computer repair shop or a web design and development firm. I need a laptop that I can code, Photoshop, stream video (hulu.com for example) without a problem, and play DVDs at decent quality.
Oh... It needs to be XP. I don't do Vista. :P This will be for work and school (papers and research) mostly, therefore I do not need to game, and there probably wont be any need to edit video on the laptop.
Some other specs... at least 2GB of RAM, DVD RW drive, ethernet port, wireless internet, 80GB HDD minimum.
Thanks for your suggestions!
- pcrobot :)
PostPosted: Thu Mar 13, 2008 12:44 pm
King of All Voodoo2 Cards
Does a low native resolution bother you?
Most (if not all) laptops in that price range have WXGA LCDs, and trying to navigate around Photoshop in a 1280x800 window is annoying, especially if you're working on something bigger then 4 megapixels.
PostPosted: Thu Mar 13, 2008 1:16 pm
If I have to do that detailed of work, I can bring it home--screen resolution isn't an issue for me.
PostPosted: Thu Mar 13, 2008 1:50 pm
This one comes in at under $700 with 2GB and Windows XP Home:
http://www.sagernotebook.com/product_cu ... ?pid=22592
You can up the processor to your liking and round it off to $800
PostPosted: Sat Mar 15, 2008 11:18 am
pifft......rookie :)
http://www.newegg.com/Product/Product.a ... 6834280007
get this, got a nice shiny 8600M and a dual core proc (AMD tho but its still goood) itll set you back $700
and then buy this memory and put it in. these puppies will make it a rocket
http://www.newegg.com/Product/Product.a ... 6820144063
dual core 8600M 2x1G tight timing MONSTER a lappy like this would usually set you back $1000 bones
PostPosted: Wed Mar 19, 2008 1:25 pm
Me? Rookie?
I'm not the one who forgot to include a copy of Windows XP on the laptop, something pcrobot specifically asked for.
Try again, junior :D
PostPosted: Fri Mar 21, 2008 1:55 pm
NOOOOOOOO i can has butter knife to slash wrists thoroughly, still, for 850 he could go my setup and it would rape urs :D
