It is currently Fri Apr 24, 2015 10:33 pm
 Post subject: bluetooth card for Acer 5610
PostPosted: Sun Jan 27, 2008 12:18 pm
I'm looking for a Internal Bluetooth card for my Acer but i can't find one. I want one that is a Mini PCI card, but i only found MSI ones that only work on MSI Laptops.
Does anybody know where i can find one?
PostPosted: Sun Jan 27, 2008 3:59 pm
King of All Voodoo2 Cards
Does your Acer have a miniPCI slot?
PostPosted: Sun Jan 27, 2008 4:42 pm
Yes i think so. It has a wireless card only.
PostPosted: Sun Jan 27, 2008 6:32 pm
So you're looking for a Wi-Fi + Bluetooth miniPCI card for your laptop?
PostPosted: Mon Jan 28, 2008 12:54 pm
Just a bluetooth card. But if it has WI-FI also that's ok.
PostPosted: Tue Jan 29, 2008 5:46 am
I seem to have run into a snag.
My understanding was that mini PCI is a standard so any mini PCI card will work in any laptop with a mini PCI slot. The catch is whether there's enough clearance inside the laptop to accommodate the mini PCI card.
A little more searching and I discovered that there's several different form factors for mini PCI: IA, IB, IIA, IIB, IIIA, and IIIB.
What we'd need to know now is what kind of form factor is your mini PCI slot.
PostPosted: Mon Mar 24, 2008 6:06 am
sorry i haven't posted here in a while, but can i post a Picture instead?
PostPosted: Mon Mar 24, 2008 9:11 am
I doubt it.
I'm not familliar with what the different variants look like.
PostPosted: Mon Mar 24, 2008 3:16 pm
hey beteks, just google for the right picture until you find the one that matches yours the best.
PostPosted: Wed Mar 26, 2008 2:44 am
Smithfield*
Smithfield*
Considering the prevalence of bluetooth on cellphones, headsets, mice, gps, etc., I am amazed at how few laptops just come with the damn things built in. Seems like the european and asian versions of a lot of the exact same models sold in the U.S. will come with it, but they nix it from the U.S. version.
Depending on the exact model of your 5610 (there are different models in the 5610 line) you may be able to get one from acer. I believe Acer is one of the companies who, as above, have bluetooth available/standard on some of their foreign market versions, iirc, so if you can manage to talk to the right person at acer, they can probably figure out the part number and order it for you. Doesn't seem to be on their website though. Path of least resistance would be to give them a call and see what they say. They should at least be able to tell you the form factor, anyway.
PostPosted: Wed Mar 26, 2008 1:50 pm
i'm going to open the laptop this week and take a picture of the mini pci.
