It is currently Tue Apr 21, 2015 12:22 pm
 Post subject: Low/High-Density RAM
PostPosted: Tue Nov 30, 2004 12:25 pm
I was poking around for RAM for my laptop, I noticed Micron Origional has 256MB sticks of PC100, one says "Low-Density" the other doesen't say anything - I bought a stick the non-low stuff. Theyre both the same price. I've also seen "high-density" notebook RAM out there as well.
What's the difference/advantage of Low vs. High-density RAM?
 Post subject: Re: Low/High-Density RAM
PostPosted: Tue Nov 30, 2004 8:55 pm
low density = less memory per chip
high density = more memory per chip
lower density is more compatible on older systems.
there isn't really any advantage other than higher memory capacity(high density) per stick of ram
PostPosted: Wed Dec 01, 2004 5:03 pm
King of All Voodoo2 Cards
There's no advantage.
Some older P6 based systems require low density SDRAM because they refused to recognize the chips with the higher densities.
