It is currently Sat Mar 28, 2015 11:06 pm
 Post subject: Express card slot vs. PC Card Slot Type I/II
PostPosted: Wed Oct 24, 2007 12:44 pm
Are the two slot type the same thing and just being called by different names or is it two seperate thing?
PostPosted: Wed Oct 24, 2007 1:08 pm
Million Club [PC]*
Million Club [PC]*
No, they're different.
PC Card (PCMCIA) is connected to the PCI bus; ExpressCard rides both the USB and PCI Express busses (hence the name.)
Also, the formfactor is different - it's not possible to insert an ExpressCard into a PCMCIA slot, or vice-versa.
PostPosted: Wed Oct 24, 2007 1:25 pm
Thank you! That cleared up my concern when looking at laptop specs.
