It is currently Sat Feb 28, 2015 11:20 pm
 Post subject: Miscelanious laptop parts source
PostPosted: Sun Oct 21, 2007 2:37 pm
Anybody know where to find the little "rubber feet" on underside of my Sony Vaio? Missing one, and while it doesn't hurt the performance, it's an annoyance.
Thanks in advance
PostPosted: Sun Oct 21, 2007 3:11 pm
King of All Voodoo2 Cards
I stick to fleaBay for used laptop parts.
PostPosted: Sun Oct 21, 2007 4:50 pm
Might have luck asking at a local computer repair store. If that doesn't work, getting spare mouse feet and using one of those may help.
PostPosted: Sun Oct 21, 2007 5:19 pm
maybe take an old mouse pad, and cut a piece off small enough to fit? you may have to shave it down as to not make the laptop crooked.
