It is currently Fri May 24, 2013 3:49 pm
 Post subject: laptop help
PostPosted: Wed Oct 10, 2007 5:35 pm
I am not sure if this is the correct area of the forum.
All I am trying to find out is if my laptop will take intelcore2duo chips at the 800 mhz fsb
the model of the laptop is ACER aspire 5920G (with the mobile 8600gt)
there is only a 1.5 ghz Intel core2 processor right now at 667 fsb (t5250), I go to acer website and they are not listing this as a processor for this laptop.
i'm not sure where to go to find out, but I'd like to find out if it will take the processors at 800mhz fsb
thanks in advance :D
PostPosted: Wed Oct 10, 2007 6:35 pm
Chief Surgeon
Chief Surgeon
I highly doubt you'll find a supported processor for one main reason - heat.
Laptops are more thermally engineered than desktops, except the ultra-small-size-of-a-ream-of-paper HTPC's. While you might be able to successfully upgrade the processor in the same family a little, going to a different family of proc's typically results in a boot failure (due to an unrecognized processor), a much slower machine (due to a higher FSB processor running at the slower FSB), or a constantly shutting down due to heat.
I'm not saying you CAN'T try it, but I doubt you'll be successful.
SC64
 Post subject: Re: laptop help
PostPosted: Wed Oct 10, 2007 6:52 pm
King of All Voodoo2 Cards
I think you've already answered your own question
PostPosted: Wed Oct 10, 2007 8:03 pm
SC64
the thing is on the acer website they list processors with 800mhz fsb and up to 2.2 or 2.4 ghz
the only thermal problems ive had is the vid card :)
but I would really love to be 100% sure before I drop $200 on a higher clocked processor
PostPosted: Thu Oct 18, 2007 8:57 am
ok, does anyone have a way of contacting acer about this?
an email, phone #, something?
just so I can find out for sure, and I couldn't find anything on acer's website.
PostPosted: Tue Oct 23, 2007 5:41 pm
I dont think you understood, they did not list the Intel T5250... which is the processor in this acer.
I checked the Intel website and found that the 965 chipset does the 800mhz fsb
i now have a 2.4 ghz with the 800mhz fsb
thanks...
