It is currently Sun Mar 29, 2015 1:23 am
 Post subject: Wifi Hotspot software
PostPosted: Fri Aug 24, 2007 8:42 am
Can anyone recommend some good hot-spot software. I bought my wife a laptop for school and I would like her to be able to find hot-spots at places like Starbucks and at her college.
I also need to get her a PDA so can someone please recommend a good site with reviews or maybe recommend a good one. She is in nursing and needs it for work.
I did Google searches on both subjects but I mostly get lame ad sites for the wifi stuff and most review sites aren't very helpful.
TIA
PostPosted: Fri Aug 24, 2007 10:48 am
King of All Voodoo2 Cards
Netstumbler
http://www.netstumbler.com/downloads/
PostPosted: Fri Sep 14, 2007 7:45 pm
Monkey Federation (Top 10)*
They make fo-pob thingies (key chain deals that look like a car door opener device on your key chain) that work good. Google it or hit up eBay. You just point and shoot, and they tell you the range/strength.
PostPosted: Sat Sep 15, 2007 5:14 pm
I like http://www.kismetwireless.net. But only on my MacBookPro. Netstumbler on the T60.
