It is currently Tue Mar 03, 2015 7:52 pm
 Post subject: new laptop
PostPosted: Thu Aug 23, 2007 8:10 pm
Hey everyone, Im going to be needing a laptop this year, and i was looking at these two diffrent lines from dell:
http://configure.dell.com/dellstore/con ... 5002X_F_2E
http://configure.dell.com/dellstore/con ... 5202V_F_1E
The reason i was looking at the Vostro is because it has a better CPU, but i was wondering what the screen on it was like. Does anyone know tthe screen res? Also, how is the body of the laptop?
thanks
PostPosted: Thu Aug 23, 2007 8:42 pm
King of All Voodoo2 Cards
Wow, looks like Intel has managed to put out a new line of graphic media decelerators.
Both LCDs appear to run at 1280x800 native, which looks really good on a 12" Powerbook, but rather shitty on a 15" Dell.
Unless you've got vision problems (ie- you need reading glasses) I'd highly recommend something with a higher native resolution.
PostPosted: Thu Aug 23, 2007 10:14 pm
i like the Vostro 1500
it would look good on a 12" anything. its just the 15" with a smaller resolution than the hight (15" 25") w/e, the bigger it is with the same resolution the more it stretches.
but imo, 1280x800 on 15" isnt that bad.
PostPosted: Fri Aug 24, 2007 5:10 am
Bah, it's like having a 20" monitor that maxes out at 1024x768.
Hell, even the 15" screen on my 6 year old laptop has a higher native resolution.
But in the end it all comes down to preference, and if that's your preference, go with it.
PostPosted: Fri Aug 24, 2007 6:59 am
o agree with you though, i would want a bigger resolution, but more likely a smaller screen to just make it more portable, unless it's one of those desktop replacements or something
 Post subject: Re: new laptop
PostPosted: Sat Aug 25, 2007 11:19 am
Celeron
Celeron
The screen is pretty good, but this is coming from someone who has used a crappy 19" CRT for the past few years. For the Vostro, you can select 1280x800 (XGA), 1440x900 (XGA+) or 1680x1050 (SXGA+). I got the 1280x800 monitor and haven't looked back. It's not that I didn't want the higher res, I just didn't think the 8600 could handle games at those resolutions. If you're not going to run any games more stressful than a casual flash game, then definitely go with whichever resolution you like.
I can't really comment on the rigidity of the body itself because I don't have experience with many other models of laptops, but I'd say it's fairly standard. It's not the most structurally sound, but it's serving me well right now.
PostPosted: Sun Aug 26, 2007 8:10 am
it depends on what you plan to use the laptop for but if you wanted a laptop just for college or business take the Vostro. If want one that can handle games too then go for a Inspiron or maybe even an XPS if you want Performance.
PostPosted: Sun Aug 26, 2007 8:42 pm
Personally, I prefer HP's laptops. I have the dv9000t, which is a 17". I think they all look better than Dell's do, although taste is relative. Check out the HP dv6500t, which is a 15.4" laptop with most of the same features, and an upgraded slightly video card.
PostPosted: Mon Aug 27, 2007 5:38 am
If you do decide to go with the H/P, I wouldn't recommend running Folding@Home on it. They don't seem to be very well engineered when it comes to heat dissipation:
http://www.maximumpc.com/forums/viewtopic.php?t=65536
