It is currently Fri Apr 24, 2015 6:23 pm
 Post subject: Notebook Sound Card
PostPosted: Mon Jul 30, 2007 1:10 pm
I have a Logitech 5.1 Speaker system and need a sound solution in order to take advantage of the surround sound. I'm looking for either a card for the expansion port or a usb solution. What I need the card to have is the 3 line out ports. Thanks for your guys' help.
PostPosted: Mon Jul 30, 2007 2:39 pm
King of All Voodoo2 Cards
The Audigy II NX was USB based and has analog surround outputs.
Only problem I had with that it required a DC wall wart.
PostPosted: Fri Oct 05, 2007 11:26 pm
if you have the PCMCIA slot, you can get an audigy2 zs notebook. it is basically a card with an adapter to the 3 analog jacks. I ran a 5.1 set of creative gigaworks speakers on it just fine... its windows only.. I just got a mac and I am probably going to sell mine soon
PostPosted: Sat Oct 06, 2007 4:28 am
If you can't spare a PCMCIA slot then use this, it works with 5.1:
http://www.newegg.com/Product/Product.a ... 6829118002
or this
http://www.newegg.com/Product/Product.a ... 6829102174
or this
http://www.newegg.com/Product/Product.a ... 6829101151
I would get the turtle beach or sound blaster if i were you.
PostPosted: Sat Oct 06, 2007 8:31 am
Being that this was over two months ago, I'm sure they've already picked something up by now.
PostPosted: Sun Oct 07, 2007 4:14 am
Oops didn't notice that. :oops:
