It is currently Thu Mar 05, 2015 2:34 am
 Post subject: When is the 8800 series coming to laptops
PostPosted: Sat Apr 14, 2007 5:48 pm
I have a laptop I bought 3 months ago in December with a 7600 GO. The best I can get right now is dual 7950GTX card in a lappy. Anyone know when the 8800 series is coming out on laptop?
PostPosted: Sat Apr 14, 2007 6:53 pm
The dates are really iffy, but the GeForce Go 8800GS might be out in may, with more models to follow. The Go GPUs have to be manufactured with a smaller die size (either 80 or 65 nm), compared to the 90nm desktop models, to deal with heat better.
PostPosted: Mon Apr 16, 2007 2:44 pm
King of All Voodoo2 Cards
I suspect there's a maximum power draw that nVidia's GPU needs to meet before the laptop manufacturers will begin integrating them into their machines.
Being that 8800's usually take two additional lines directly from the PC's power supply, it may be a while before we see them.
There are rumors that a SLI based Quadro 3500M was going to be out at the end of the month, but I think that was just speculation.
PostPosted: Tue Jul 24, 2007 1:46 pm
They're avalible check here: http://www.dell.com/content/products/co ... dhs&~ck=mn
except they're not 8800 but they are Geforce 8.
PostPosted: Mon Jul 30, 2007 2:19 pm
8400 and 8600 mobility chips.
A 7900 mobility could probably outrun the two of them.
