It is currently Sun May 19, 2013 5:17 am
 Post subject: Stickey Keys
PostPosted: Sat Aug 21, 2004 8:49 pm
So apparently when youre watching a DVD and drinking gatorade, and you drop the gatorade, it will find a way to defy gravity and land 3 feet above and to the side in order to land on your laptops keyboard.
So, this Dell Inspiron 9100 has a stickey space bar (its pretty bad...it almost feels like it doesnt move unless you directly press down on it).
Is there anyway to get under the keys to clean in there?
I kind of dug around a little but none of the obvious screws seem to do anything...
I need to know ASAP, thanks.
PostPosted: Sat Aug 21, 2004 10:36 pm
Only sure fire way will involve (most likely) a small torx screwdriver and several hours of warrenty voiding dismantling and reassembling of the laptop. If you choose this path, I'm not to be held responsible for any screwups that occur, such as random screws that appear after reassembly when you're certain you put everyone of them back where it goes :)
PostPosted: Mon Aug 23, 2004 9:31 am
Yeah I got any of the little phillips head screws out I could, but it did no good :\
PostPosted: Mon Aug 23, 2004 10:37 am
King of All Voodoo2 Cards
Are the keys removable?
On my laptop you can remove the keys to clean underneath them by pulling up on both sides of the key at the same time. On my friend's laptop you pull up on the top part of the key at a 45 degree angle and they pop right off.
PostPosted: Tue Aug 24, 2004 7:42 pm
I'm kind of afraid they are just glued to something...
But I cant really check now, I moved out and it's a 3 hour drive to my parents house.
