It is currently Wed Jun 19, 2013 7:34 am
 Post subject: Upgrading my Dell Inspiron 1150
PostPosted: Fri Aug 20, 2004 9:43 am
I have a Dell Inspiron 1150 and I want to upgrade the hard drive from a 20G to 40-60G. Ive gone to the dell site and try searching for a hard drivee that would fit a 1150, but couldn't find any. I would like to know if anybody knows where I get one?
 Post subject: Re: Upgrading my Dell Inspiron 1150
PostPosted: Fri Aug 20, 2004 10:39 am
King of All Voodoo2 Cards
Any 2.5" 9.5mm drive will fit into it. Dell also occasionally used 2.5" 11mm IBM drives in some of their high performance notebooks.
If you want to be sure that it's 100% compatible, stick with the 9.5mm, they fit into everything.
If you're looking for a reseller try:
http://www.ewiz.com
http://www.newegg.com
They both sell 9.5mm 2.5" notebook drives.
