It is currently Sun Apr 26, 2015 7:40 am
 Post subject: Lenovo Idea Pad 510p - Is this a good deal?
PostPosted: Mon Dec 16, 2013 10:03 pm
Is this a good deal for $899.00?
- Processor 4th Generation Intel Core i7-4700MQ Processor (2.40GHz 1600MHz 6MB) +
- Operating system Windows 8.1 64 +
- Display 15.6" FHD LED Glare Wedge 1920x1080 +
- Graphics NVIDIA GeForce GT755M GDDR5 2GB +
- Memory 8.0GB PC3-12800 DDR3L SDRAM 1600 MHz +
- Hard Drive 1TB 5400 RPM+24GB SSD +
- Optical Drive DVD Recordable (Dual Layer) +
- Network Card Intel 7260 b/g/n Wireless (2x2 BGN) +
- Bluetooth Bluetooth Version 4.0 +
- Warranty One year +
- Battery 6 Cell 72 Watt Hour Lithium-Ion
I'd like to play guild wars 2 with it if I could, if not that's fine, games like Terraria and such will work for sure I'm sure.
 Post subject: Re: Lenovo Idea Pad 510p - Is this a good deal?
PostPosted: Mon Dec 16, 2013 11:10 pm
I can also add a second of the same video card for +$150
PostPosted: Mon Dec 16, 2013 11:38 pm
As it is, the laptop is a good deal. However, adding the second video card, while it will improve performance quite a bit, will add considerable heat and power consumption.
http://www.notebookcheck.net/Review-Len ... 470.0.html
PostPosted: Mon Dec 16, 2013 11:57 pm
Power consumption I am not so worried about as it will be plugged into AC 90% of the time it is in use. If the extra heat is going to reduce its logevity however that would be a concern.
Maybe I am better off just to stick with the one video card.
