It is currently Fri Jan 30, 2015 3:27 am
 Post subject: Good Place To Get used laptops
PostPosted: Sun Aug 15, 2004 9:08 pm
I was wondering what a good website is to get a good used laptop, looking for something cheap but good (if it exist). say $400 or below.
looking for a good sized HD 10 gig or above and a decent speed of above 4200rpm's. usb port, place for a nic card dvd or cd-burner kit floppy kit.
400mhz proc if possible.
I am not very familair with laptops since i have never owned one or had the money for one until now.
mainly for internet use, movie playing, nothing too big.
any help would be great thanx.
PostPosted: Mon Aug 16, 2004 2:53 pm
King of All Voodoo2 Cards
I don't think you'll find anything like that for under $400 if you want my honest opinion. Plus with a used laptop like that, you'll find that the battery can only take two thirds or only half a charge. The screen is only XGA with a few dead pixels, and the overall system is not in the best of condition.
The BestBuy in my area usually gives out flyers in the mail, I would look there first only because I've occasionally seen a nice Toshiba Laptop for $789 on sale. I would try to save up a little more money and buy something that will last a little longer then a used laptop if I were you.
If you're still adament about getting a used one you can try the following:
http://www.notebookmall.com/
http://www.usedlaptopsonline.com/
http://www.discountlaptops.com/
http://www.usedlaptopcomputers.com/
http://www.laptopoutlet.com/
:arrow: :arrow: HOWEVER, before you buy from any of these dealers, be sure to look them up on reseller ratings FIRST!
PostPosted: Mon Aug 16, 2004 9:34 pm
Thanks for the info, I will keep a eye out for best buy ads, but i will prob still end up getting a used one.
PostPosted: Tue Aug 17, 2004 1:00 pm
check the manufacturer's websites for refurbished laptops.
PostPosted: Fri Aug 20, 2004 9:50 am
You could give ebay a try. :)
PostPosted: Sun Feb 27, 2005 9:40 am
You can try Here
