It is currently Mon Apr 20, 2015 5:37 pm
 Post subject: Greyed Out
PostPosted: Fri Aug 12, 2005 7:41 pm
:cry:
Tungsten T; hot sync fails and menu is greyed out, so cannot inspect settings.
What's next?
PostPosted: Fri Aug 12, 2005 9:04 pm
King of All Voodoo2 Cards
Is the Palm HotSync Manager running?
What version of the Hotsync Manager do you have installed?
 Post subject: Palm HotSync
PostPosted: Fri Aug 12, 2005 9:19 pm
I am running Hot Sync Manager 4.0. Palm recognized in crade; do get a beep when hot sync is pressed, but:
no window on desktop
hotsync menu items greyed out; cannot access; pc reboot fails
time-out on sync
PostPosted: Sat Aug 13, 2005 3:06 pm
Have you tried resetting the Palm?
PostPosted: Sun Aug 14, 2005 9:21 am
Yeah, I tried a soft reset. Hey, you know what? I solved my own problem.
Some time ago I had had some pc software conflicts, so I ran msconfig.exe and removed most third party apps. from Startup. This included the HotSync app!! So when I restored it, the HotSync app was no longer greyed out and I synced fine!
So the problem wasn't even related to a Palm malfunction. I was the one who created it unknowingly!!
PostPosted: Sun Aug 14, 2005 12:52 pm
I did the same thing to mine, I just manually boot up the HotSync manager whenever I load up Palm Desktop
PostPosted: Sun Aug 21, 2005 9:03 am
Hotsync is satan- I just put everything I need on an SD card in my Treo and tranfer it manually.
