It is currently Sun Mar 01, 2015 9:06 pm
 Post subject: Notebook opticals?
PostPosted: Thu Aug 04, 2005 1:09 pm
Smithfield*
Smithfield*
I guess there isn't one single standard for notebook opticals. I recently bought a "slim" drive and tried to pop it into my nice new asus notebook only to find that it is too small. Can someone help me out in finding the correct form of optical drive for my asus Z71A notebook.
PostPosted: Thu Aug 04, 2005 2:03 pm
Search pricewatch.com. They have tons of stuff. If you can't find what you're looking for under the different catagories, search for "asus z71a optical" comes up with a bunch of stuff.
Then check reputable online vendors like new egg and zipzoomfly for the part you found. Or check on resellerratings for the vendor's site where you found the drive.
PostPosted: Thu Aug 04, 2005 2:15 pm
King of All Voodoo2 Cards
I don't know about Asus, but I know that Clevo uses caddies for most of their drives so you can buy a drive, screw it into the caddy then slide the caddy into the laptop. Of course, if it's a different color it might look a bit funny.
PostPosted: Thu Aug 04, 2005 7:29 pm
Smithfield*
Smithfield*
*sigh* i hate propriatary shit. Had to order a drive from buy.com that was specifically for the computer. 140 bucks, jeez.
PostPosted: Fri Aug 05, 2005 5:21 pm
i always thought that the bare optical drives had the same formfactor. the only difference is the front bezel to match the bodylines of the laptop. they are all wrapped in proprietary caddies and connectors, but those can be disassembled.
PostPosted: Fri Aug 05, 2005 6:59 pm
Smithfield*
Smithfield*
so did I... and we are both wrong
PostPosted: Fri Aug 05, 2005 7:39 pm
Yeah, I've got a bunch of different opticals for my laptop:
Toshiba DVD-ROM Region Free
Torison DVD-ROM Region-1
Panasonic CD/RW Drive
