It is currently Wed Mar 04, 2015 7:54 am
 Post subject: compaq armada e500 - upgrading hard drive?
PostPosted: Sat Jul 30, 2005 5:39 pm
i want to upgrade the hard drive on my compaq armada e500 to something larger than 10gb. i've found hard drives online that are advertised as being compatible with this laptop but they are usually more expensive than ones i find that aren't. what should i watch out for to try and be sure the drive i get is compatible since i've never upgraded a hd on a laptop before? the specs on the drive that are in the system right now are as follows (from the compaq service manual):
user capacity: 10GB
Drive type: 65
Drive height (with drive frame, in mm): 9.5
Drive width (with drive frame, in mm): 70.0
2.5 inch formfactor: yes
Sector interleave: 1:1
Interface type: ATA-4
Disk Rotational Speed (rpm): 4200
i left out things like transfer rates and seek times and cylinders and heads cause i didn't think it's relevant but let me know if it is. so obviously i need to buy a 2.5" drive that has roughly the same dimensions (or at least isn't much larger). what about rpm's though? is 7200 ok or should i stick to 5400 or even 4200 like the original (shudder)? please help, i'm a total noob at laptop upgrading :oops:
PostPosted: Sat Jul 30, 2005 10:28 pm
this is the one i'm looking at...anyone see any problems?
http://www.newegg.com/Product/Product.a ... 6822152503
PostPosted: Mon Aug 01, 2005 10:10 am
King of All Voodoo2 Cards
Problem #1 - It's made by Samsung. Now, don't get me wrong, they make great LCDs, Plasmas, and DDR memory, however their HDDs leave a lot to be desired. If you want a good boost in speed look for the 7,200 RPM 60GB Toshiba and see if they're making it with a 16MB cache rather then the standard 8MB.
Problem #2 - There's no height listed in the newegg ad. If that turns out to be a 12mm drive, you're SOL because you need a 9.5mm drive.
My recommendation =
http://www.newegg.com/Product/Product.a ... 6822149020
It's 9.5mm, it's got a slightly better latency then the Samsung, double the cache then the Samsung, and the 3 year warrenty would be a lot more desirable over the Samsung's 1 year warrenty. But I'll let you decide if that's worth the extra $15. :D
PostPosted: Mon Aug 01, 2005 5:18 pm
agreed...that is a better drive. where does it say that it's 9.5mm? (i'm assuming it is since it's "slim") thanks though...i'll be getting that drive i think. any forseeable problems installing it in an older system like this?
PostPosted: Mon Aug 01, 2005 5:42 pm
All the Toshiba 2.5" drives are 9.5mm.
I replaced a 30GB, 4,200, 2MB drive with a 40GB, 5,400, 16MB drive with no problem. Sped things up a lot.
PostPosted: Mon Aug 01, 2005 6:08 pm
cool thanks...now if my new power adapter will get here so i can turn the laptop on.... :roll:
PostPosted: Sun Aug 14, 2005 10:24 am
hard drive has been in for about a week and is dual booting xp and gentoo beautifully (50GB for xp and 30GB for gentoo)...started compiling open office last night and it's still going grrrr...anyways, thanks for the suggestion. it appears to be working fine.
