It is currently Tue May 05, 2015 12:16 am
 Post subject: power plug repair question
PostPosted: Thu Mar 24, 2005 11:42 pm
hi I am totally lap top illiterate. I have built quite a number of desktop mahines tho & one of my friends asked me to see if i could fix his compaq 1255. I tore it open & behold the power plug was broken off inside it & loose. I can see that it has snapped the connector & looks like it was only hot glued on from the oem. If I solder the broken connection(only one pin sticking into the mobo) & hot glue the unit back into place will this work or should i have him spring for a new mobo. I just wanted to get someone more knowlegeables opinion before I started working on it.
PostPosted: Fri Mar 25, 2005 9:31 am
King of All Voodoo2 Cards
Is the warrenty still valid?
PostPosted: Fri Mar 25, 2005 10:07 am
No its an old one got a K6 processor my friend is just too cheap to upgrade yet.
PostPosted: Fri Mar 25, 2005 10:13 am
Is he holding you responsible if it doesn't work or you screw it up?
PostPosted: Fri Mar 25, 2005 10:21 am
No he wants to get it working but he wants to spend as little cash on it as possible. Replacing the mobo would get it going for sure but patching would be lots cheaper as the mobo is really hard to find & runs about $110.
PostPosted: Fri Mar 25, 2005 10:25 am
I'd solder it, and then hotglue the plug back into place
PostPosted: Fri Mar 25, 2005 10:36 am
thx hopefully that will work til he decides to spring for a new one.
PostPosted: Fri Mar 25, 2005 5:48 pm
Smithfield*
Smithfield*
Yeah, if it's broke already, I doubt you can break it more. Worth a shot anyway. Let us know how you make out!
PostPosted: Fri Mar 25, 2005 9:23 pm
Will do Urvile..unless it blows up or something lol.
