It is currently Sat Apr 25, 2015 1:39 am
 Post subject: Can I run an OS from an external drive?
PostPosted: Fri Mar 18, 2005 9:18 pm
I was thinking it would be cool to have a complete windows XP installation on an external HD (usb 2.0) and then have the ability to boot from it. Is that possible?
PostPosted: Sat Mar 19, 2005 5:16 pm
I personally don't know for sure...sounds like it could be tough....but probably could be done...somehow
PostPosted: Sat Mar 19, 2005 6:36 pm
it should be possible, but to move it from pc to pc would be impossible.
PostPosted: Sat Mar 19, 2005 7:08 pm
What if I used a different type of connection? Like firewire. It seems like there should be a way to make the bios think its a floppy or CDROM, then tell it to boot from there.
PostPosted: Sun Mar 20, 2005 8:52 am
the change in hardware would probably stop windows from running.
PostPosted: Mon Mar 21, 2005 8:10 am
Team Member Top 100
Team Member Top 100
nah, a lot of newer computers can support booting from USB, my laptop does support it, although it's only USB 1.1, so booting from a USB drive would be very painful. I have in the past, installed windows onto my iPod, and booted off of there on my desktop in the past. I just wanted to see if it could be done, turns out, it can.
 Post subject: Re: Can I run an OS from an external drive?
PostPosted: Mon Mar 21, 2005 8:42 am
King of All Voodoo2 Cards
If your BIOS supports booting from USB then yes.
PostPosted: Tue Mar 22, 2005 12:46 am
Simple, connect your USB drive, set your BIOS to boot from CDROM, put the XP CD in the tray and CTRL ALT DEL. Your external drive will appear while you go through the install process. It's not advisable to do it this way, but it can be done.
