It is currently Thu Jan 29, 2015 7:24 am
 Post subject: Dell Battery matching
PostPosted: Thu Mar 10, 2005 8:31 am
Phoenix Foundation (Top 10)
Im pretty sure i can do this, but as always, better to have someone else say you can as well, especially when your dealing with $1000 piece of hardware.
Battery in my 5160 is:
14.8v 6450mAH 96WH
Battery in 1150:
14.8v 4300mAH 65WH
Can I use the 1150 battery in mine? They both look and fit the exact same. Common sense tells me they are both the same battery type, same voltage, only difference is one lasts longer then the other. (96 compared to 65)
PostPosted: Thu Mar 10, 2005 10:10 am
King of All Voodoo2 Cards
If they're the same size and shape with the same connectors, then I would say it's simply a matter of cells.
The 5160 battery has more cells then the 1150 (possibly the difference between a 6, 9, or 12 cell Li-Ion battery)
If that's the case then yes, they'd work.
