It is currently Sun Jan 25, 2015 5:41 pm
 Post subject: Centrino vs P4 on FPU?
PostPosted: Wed Mar 02, 2005 12:21 pm
Hey guys... considering getting myself a Centrino based Laptop since I like the portability of it more. Lots of places claim that the 2.0ghz centrino performance is equivilant to a 3.0ghz P4... not sure if this is true. I do a lot of 3D rendering (I work in VFX) which involves a lot of raytracing, and may do some of that on my laptop. Raytracing tends to be very heavy on floating point, and I was told (but can't confirm) that the centrino tends to have a poor floating point performance. Is that true? Tried to find some specific benchmarks (FPUMark benchmarks, etc..) but can't really find any. Anyone know of any good sites that do a complete breakdown of benchmarks of Centrino (hopefully newer ones like 2.0ghz or better), versus P4s?
PostPosted: Wed Mar 02, 2005 12:27 pm
If you are looking for battery life, Centrino is the only way to go. If you are looking for preformance, then a P4 may be the way to go, but you are taking a major cut in battery life. While most Centrino notebooks sport 4-5 hour batteries, most of the P4 notebooks have 1-2 hour batteries.
PostPosted: Wed Mar 02, 2005 1:23 pm
Actually, I'm very familair with the battery life on the centrino, which is why I was considering it in the first place. I am simply wondering more specifically about the loss in performance I would experience... specifically, floating point performance.
PostPosted: Wed Mar 02, 2005 2:57 pm
King of All Voodoo2 Cards
Is Raytracing bandwidth intensive?
If so the Pentium M would suffer against a Pentium 4 because of the lower bus speed and slower memory.
Read here for a few more performance specs:
http://techreport.com/reviews/2005q1/df ... dex.x?pg=1
PostPosted: Wed Mar 02, 2005 3:52 pm
Thanks flytrap... that is exactly what I needed to know...
Check this out:
http://techreport.com/reviews/2005q1/df ... ex.x?pg=16
POV is a pure raytracer, so it proved to be a perfect FPU benchmark.
Users browsing this forum: ayoub and 2 guests
