It is currently Mon Mar 02, 2015 4:37 pm
 Post subject: Dell laptop
PostPosted: Thu Feb 24, 2005 10:27 am
I have a Dell Inspiron 8100 laptop in need of repair, identical to the one seen here at Gamers Depot.
System Specs:
:twisted: Processor: Intel® Pentium® III Processor 1.2GHz-M
8) Display: 15in UltraXGA TFT Display
8) Memory: 512MB, 2DIMMs
:twisted: Video Card: 64MB 4X AGP ATI Mobility Radeon 7500
:shock: Primary Hard Drive: 60GB Hard Drive
:roll: Floppy Drive: Modular Floppy Drive
8) Operating System Software: Microsoft® Windows® XP Professional Edition SP2
:twisted: Modem: 10/100 + 56K Capable V.90 NIC/ Modem, Internal Mini-PCI
8) Removable CD/DVD Drives: 52X CDR-RW/ 8X Max Variable DVD
Note that i'm working on a "Transfer of Ownership" with the manufacturer, being that the previous owner is at sea for approximately six months, i won't be able to accomplish the transfer until he returns. With that said, It's been giving me problems since I bought it. I'm looking someone who knows the 8100 series laptops better than I do, I'm looking for a real Einstein. :P Can sombody save me!?
Here's my problem: Upon powering up, these systems have a primary login prompt. I need assistance to override this prompt so that I can get into the system. I took the mainboard out and got this Dell Part Number:6K117. I've tried cutting the power overnight from the internal auxiliary battery to reset things, but i'm having no luck. So any other cost saving suggestions, or ideas including where I can perform a jumper/solder on the system board would be greatly appreciated.
PostPosted: Thu Feb 24, 2005 12:15 pm
Are you talking about a BIOS password, or a Windows password?
PostPosted: Thu Feb 24, 2005 3:11 pm
neither one
Aside from the Windows password (which is not set) this laptop has three other password prompts. Two of which I'm not concerned about, and they are the bios & hard drive passwords (these two have not been set as well). What I need is the primary login password.
Primary login Password: This is the power-on password that will prevent the system from booting (completing the POST) unless the correct password is entered
Bios Password: Self explanitory...prevents changes from being made to the system setup/bios properties.
Hard-Disk Drive Password: This password stays with the hard drive if the drive is moved to another system.
For clarification purposes:
I've been asked by others, why do I need the primary password if the bios password has not been set?
This is because the computer powers up to a blue screen prompting me for the primary password. If I had the primary password, I can use the computer nomally.
Till then I can't enter the bios to make any changes whatsoever.
PostPosted: Thu Feb 24, 2005 3:38 pm
King of All Voodoo2 Cards
Look for the laptop's clock battery and remove it for a little while. It'll look something like this:
If you've already done that and the password is still there, it's probably not a BIOs password, and probably software based.
At that point I'd say to remove the laptop's internal HDD, stick it in an external Firewire or USB enclosure, attach it to a working system and then format the drive. Drop the drive back into the laptop and install a fresh copy of whatever OS your prefer on it.
PostPosted: Thu Feb 24, 2005 5:56 pm
Flytrap7 wrote:
Look for the laptop's clock battery and remove it for a little while. If you've already done that and the password is still there, it's probably not a BIOs password, and probably software based.
ok, i got that far, here's what it looks like on an inspiron
next step...
conclusion: primary login pops up immediatly, asking for user name and pasword. System is still inacessible...any idea what the cmos chip looks like?
PostPosted: Thu Feb 24, 2005 6:23 pm
Were there two partitions on that HDD when you formatted it?
I've see a few Dell (and other manufacturers) that have a 10MB partition at the beginning of the drive to store system settings and information.
EDIT: If you format that partition, you'll need a system restore disk to put it back.
PostPosted: Thu Feb 24, 2005 6:29 pm
Smithfield*
Smithfield*
hummm. so the second you power up it asks for a password? no post or anything? thats fuxoring strange. i was gonna bust out ERD commander to kick the computers ass but if you cant even get it to boot to a floppy then forget it.
PostPosted: Fri Feb 25, 2005 4:30 am
yup, takes about a second or two. sounds like Big Guns...yikes!
i'm sure it's something good but, that one flew over my head. :)
havn't got a clue about the Commander. i'll look it up...thanks
edit:
yup, yup, was prepared for that...I wiped it clean...It had a ten gig partition for the mfr install, twenty for the OS, and the remainder for music. Let me know if you have any other suggestions cause i'm still stuck between a rock and a hard place.
Update:
BTW: my uncle knows someone with the same make and model. He's telling me that his friends LCD display blacked out on him, and will be calling me back.
2nd update:
Just called the other guy needin' a display and he said it's going to cost him $713.75 locally to have it replaced. So I told him about my lappy, and he says he ain't gonna wait a few more weeks for his Dell part to come in. I think he's getting the run around, as usual. Anyway, we closed a deal for a decent price, i'll be changing out his display, upping the 30GBHD to a 60, and swapping the GPU. I'm relieved to know that my headaches have been sold.
no Dell...no problem :P
PostPosted: Fri Feb 25, 2005 2:02 pm
Can I suggest a few great alternatives to Dell/Gateway/eMachines/Toshiba/HP/Shitpaq/etc:
www.pro-star.com
www.sagernotebooks.com
www.eurocom.com & www.eurocom.ca
PostPosted: Fri Feb 25, 2005 3:55 pm
Daveyd, you know how to swap out a GPU for a dell? I got a 5100 with a 32MB radeon 7500 that I could use replaced for a better gpu. I haven't had much experience inside a laptop but I replaced my HDD and opened it up once to clean it out. If you know where to find a GPU for mine and think I could do it myself, let me know. I would like a price estimate too, thanks.
My other specs are pretty good.
- 512mb ram
- 60gb 7200rpm hitachi
- 2.4ghz P4A
PostPosted: Fri Mar 04, 2005 3:00 pm
hit up support.dell.com, they should have online documentation for their laptops. http://support.dell.com/support/edocs/systems/ins5100/en/sm/index.htm
shows you howto get to the GPU.
the only upgrades to your setup i know about would be the Mobility Radeon 9000 or the GeForce FX5200 Go. there is a chance you can order them from dell spare parts (phone only, not online ordering). right now ebay has these http://search.ebay.com/inspiron-5100-video_W0QQfromZR40QQsojsZ1 GPUs listed.
i upgraded my inspiron 8000 from the ATI m4 to m9, this upgrade wasn't supported by dell and i had to get drivers from www.omegadrivers.com.
PostPosted: Fri Mar 04, 2005 3:53 pm
I saw a few that would fit yours on fleaBay.
Here's a completed one just to give you an idea what to look for:
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... eName=WDVW
