It is currently Tue Jun 18, 2013 2:27 pm
 Post subject: Dell precision m4300 is overheating
PostPosted: Wed Jun 01, 2011 11:48 am
Hi,
I am running "windows 7 enterprise 64 bit SP1" on a "Dell precision m4300" (new install) and the laptop is boiling hot :!:
It seams the fan is not running at all.
I don't think this is a hardware issue; I have sprayed compressed air (without opening the laptop) to clean up the fan.
Also, before installing W7 (from scratch), I had WXP 32 SP3 installed on that same machine and the fan was working just fine.
I heard about a software called "i9kfan" that might help me but could not find anywhere a download link.
I am not sure what the problem might be (BIOS, Hardware, Software...)
Sorry if I am not on the right forum...
The only yhing I know is that if I do not find a solution quickly, my laptop will fry ... :cry:
Thanks in advance for any advice :)
 Post subject: Re: Dell precision m4300 is overheating
PostPosted: Tue Jun 07, 2011 7:31 am
Million Club - 20 Plus
The fan could very well have failed or its connector could have come loose.
Also, from what I've heard, spraying compressed air into the fan is very bad for it.
Ted
PostPosted: Sun Jun 12, 2011 1:03 pm
thanks for your reply.
Is there any way I can figure out if this is a hardware or a software issue ?
Thanks
