It is currently Sat May 18, 2013 7:02 pm
 Post subject: Looking for a USB Stick that accepts TWO MicroSDHC cards
PostPosted: Thu Dec 30, 2010 4:30 pm
Does such a thing exist?
I am looking to have a usb stick that can accept two MicroSHDC cards at the same time
and have both card recognised in windows at the same time.
Can you guys help.
 Post subject: Re: Looking for a USB Stick that accepts TWO MicroSDHC cards
PostPosted: Fri Dec 31, 2010 12:53 am
Can you guys help.
I think you are out of luck. I've only seen them that will accept one. Just out of curiosity, why? If you want to copy from one to the other you could make a folder on your hdd and copy to that, then copy from the folder to the second micro. Or get a card reader that accepts micro sd, most of the new ones do, and a usb stick that will accept a micro sd and copy from one to another.
PostPosted: Fri Dec 31, 2010 8:12 am
Can you guys help.
I want to do it because I want to increase the amount of storage I have on me when I am away from home. For example my PMP has an On-The-Go cable that allows me to play media from usb devices.
The player has 16gb I have a 32 GB card in the player as well and I was hoping to put two 32GB cards in on USB stick and get myself another 64 GB.
The concept is not unprecedented tere are memroy stick compatible devices that allow the use of two microsdhc cards.
http://www.amazon.com/PhotoFast-MicroSD ... CXENH1PD63
At any rate thanks for the bump.
