If you're a newbie, or just don't feel confident messing around in your webbook's innards, get a tech to work on it for you. That said, before you do anything else, do your homework. From a little quick research, it looks like the ram type is DDR2. I can't find what freq. it's running on, but it looks like it's indeed one stick of ram. As Ted said, the R40 uses a different kind of ram (DDR), so you won't be able to switch them. Even if you could, you could only put one in, so there'd be no improvement. If it were me, I'd go on Newegg, where you can find a 1 gig stick of DDR2 for as little as $20/£12.90. Hope this helps.
