It is currently Sun Mar 01, 2015 1:05 am
 Post subject: Here Is EASY Way to Make FREE Ringtones
PostPosted: Fri Jul 23, 2010 1:47 pm
Came across this FREE program and it rocks. It allows you to cut portions of your favorite MP3 to use as a ringtone. Instructions are super easy. It's called MP3 Cutter.
Each cell is different how it stores music files so you have to do some legwork there. If you are on Virgin Mobile like me, I know exactly how to save MP3's for ringtones.
Look for another program called Format Factory. It re-saves your MP3 into another MP3. Don't know why but you gotta do this with your ringtone. Rename the MP3 to a .3g2 file. PC will ask if it's okay just say YES. Drag this onto your cell.
Once it's on your cell, go and find the file, then select Assign and Assign it as your new ringtone. Good luck.
PostPosted: Sun Aug 01, 2010 12:17 pm
There's many ways to cut songs into clips, so this is just one. After that, it should be as easy as connecting to the computer you made it from and placing it in your music folder. Or go a step further and make a "Ringtone" directory in there for easy location.
I've got plenty of paid software to do this, but I have friends with none at all and get it done.
