It is currently Sun Mar 01, 2015 12:05 pm
 Post subject: Laptop Graphic cards
PostPosted: Fri Apr 23, 2010 2:11 pm
Anyone know if or when nvidia would be coming out with a GTX380 series for notebooks, and whether it would be possible to upgrade my GTX280M's to those?
 Post subject: Re: Laptop Graphic cards
PostPosted: Fri Apr 23, 2010 3:20 pm
Million Club [PC]
Million Club [PC]
No. The GTX 380 doesn't, and probably never will, exist. A GTX 480M? Perhaps, but they've got their work cut out for them. Their current next-gen architecture is entirely unsuitable for use in notebooks.
As for upgrading, likely not, but its possible. What notebook do you have?
 Post subject: notebook
PostPosted: Sat Apr 24, 2010 4:36 am
I have a M980NU Laptop from Avadirect.com, the older version of the X8100 they now have.
PostPosted: Sat Apr 24, 2010 7:28 pm
You may wanna check on this topic in which had been posted and I found it worthwhile for niche requirements!
http://www.maximumpc.com/forums/viewtopic.php?t=99160
 Post subject: GTX480M
PostPosted: Mon May 03, 2010 2:56 am
Just read that Eurocom is going to be coming out with a laptop that has the option for single or SLI GTX480M's, which from what I read is going to be available in June. Unless I read something wrong.
PostPosted: Mon May 03, 2010 3:43 am
Million Club [PC]
Million Club [PC]
Well, there is the rumor indeed. The GTX 480M is going to have to be a lot less powerful than the current 480M because of power use. Hopefully I'm wrong. Also, does your M980NU have one or two 280Ms? It's unlikely that a 480M will work with it, but to increase performance you can buy a second 280M and SLi it. Honestly, otherwise its difficult. That's what you signed onto when you bought a high-end notebook: poor performance for the price, poor battery life, and very limited upgradeability.
PostPosted: Tue May 04, 2010 2:25 am
I already have 2 GTX280M's in SLI right now, but the 480M's and mine both have the same connection type, MXM 3.0 Type-B so I think it could work to change them out.
PostPosted: Tue May 04, 2010 2:28 am
Million Club - 20 Plus
What about the thermals? They probably run much hotter.
Ted
