It is currently Wed Apr 01, 2015 3:06 pm
 Post subject: How do you rate these laptop video cards?
PostPosted: Wed Nov 18, 2009 6:01 pm
Actually, I'm not sure if they are called cards or chips.
I was configuring laptops and came across these video chips:
Nvidia GeForce G210M
Nivida GeForce 9500M
ATI mobility Radeon HD 4670
How would you rank these 3 in terms of video processing horsepower?
Would the first one be considered powerful enough for games & graphics programs? It's available on a Dell 13" I have in consideration.
PostPosted: Wed Nov 18, 2009 6:14 pm
Team Creamsicles
Team Creamsicles
4670 is fastest, G210m is second, and 9500m is last.
The 4670 should be good enough for nearly every game out at medium settings with a low resolution of WXGA or less.
PostPosted: Fri Nov 20, 2009 6:00 pm
Thanks for that info.
After posting I did find this site that compares graphic cards for notebooks.
It might be helpful for others.
http://www.notebookcheck.net/Comparison ... 130.0.html
PostPosted: Sat Apr 17, 2010 6:56 pm
What sort of graphics programs in whcih you be running in the Dell latop?
What's your usage percentage for gaming / graphics programs?
What sort of after sales support / warranty you be looking for?
What's your budget intended for the purchase?
AS that if for home usage even though not for gaming, the Dell's Small & medium Business series is also worth looking at .
And also if you are into graphic programs, eg 3D studio max, autocad, etc...
The Dell Inspiron will not be so suitable.
Cheers!!!
