It is currently Fri Jan 30, 2015 9:14 pm
 Post subject: Is it possible to upgrade toshiba m500 video?
PostPosted: Fri Jan 22, 2010 3:03 pm
My employer recently purchased a number of toshiba m500 notebooks. The notebook is serviceable but mediocre. Of course they purchased it with the built in Intel Graphics Media Accelerator 4500MHD, I am wondering if it is possible to upgrade to the NVIDIA® GeForce® G 210M discrete graphics with 512MB DDR3 dedicated memory myself as this is a factory option
PostPosted: Fri Jan 22, 2010 7:45 pm
Chief Surgeon
Chief Surgeon
Do you have a full model number of said laptops. It will help to determine if it's indeed possible.
Check the underside for a sticker which should have it.
PostPosted: Sat Apr 24, 2010 6:36 pm
You may have to approach Toshiba as that could be a module card to be installed by certified technicians.
Same thing as Dell (expecially their business models) also come in various module cards but rather hard to obtain them from outside and voiding their warranty!
Isn't the Intel GMA 4500MHD good enough as versus the previous 3100 or earlier series?
What are the types of your applications that require the upgrade into the GeForce graphics?
