It is currently Sat Jan 31, 2015 3:49 am
 Post subject: Good book(s) about hardware?
PostPosted: Sat Jun 20, 2009 6:21 pm
Does anyone know of some good, comprehensive reference books about hardware? An encyclopedia of sorts? Any input is appreciated.
PostPosted: Sat Jun 20, 2009 11:41 pm
TravBv2.0
TravBv2.0
With how fast computer hardware changes, the best you'll find won't include the latest tech that we've been hearing about for a while now (Like Core i7).
Scott Mueller has the best actual books concerning hardware though.
http://www.amazon.com/s/ref=nb_ss_gw_1_ ... Scott+Muel
PostPosted: Sun Jun 21, 2009 3:47 am
Yeah I figured it would be nearly impossible to find something up to date in print. Thanks for the info TLG.
PostPosted: Sun Jun 21, 2009 5:46 am
Malware specialist
Malware specialist
Computer hardware does change frequently, but the basics are all the same (in most cases).
Pick up a good book as TLG mentioned and start reading it.
Once you have an understanding of what is in a computer and what each part does, you should be able to migrate all that knowledge to the newer set of processors/motherboards/etc.
 Post subject: hardware
PostPosted: Wed Jul 15, 2009 9:08 am
This is pretty close to a hardware bible, but if they haven't done a third edition it might be a bit dated. In anycase, it's a good read.
http://www.amazon.co.uk/Art-Electronics ... 0521370957
PostPosted: Wed Jul 15, 2009 10:51 am
Thanks engless
