It is currently Mon Apr 27, 2015 9:31 am
 Post subject: CCNA for a novice
PostPosted: Mon Jun 18, 2007 8:27 am
I need to get a CCNA cert for work. Can anyone tell me where I should start. I have a little knowledge with hands on experience configuring routers and access lists/router tables using OSPF, but it's been 3 years since I looked at a router. I have read dozens of similar post and a few recommended the BryantAdvantage stuff and a book called Introduction to Cisco Router Configuration. Where would I get an emulator to work with, I don't have the money or room for actual hardware and I'm about to move and will only have my laptop available to work with. Any help would be great. I have 6 months to get the cert, so time is available. I think a boot camp would probably be too expensive right now. Thanks for the help
PostPosted: Wed Jun 20, 2007 7:18 am
http://www.dynagen.org/
only tricky part might be getting the IOs images. It does not at the moment support swtich images but at the very least it could be a good place to start
 Post subject: Suggestion
PostPosted: Fri Jun 22, 2007 7:01 pm
Hi,
I have achieved CCNA on my own and have gone on to get CCNP, which is like 4 CCNA tests and am just going for my CCIE this year. I have done this with many study tools but the most important one for me was very simple, www.routersim.com
Buy the CCNP one. It does everything you will need and then some.
http://www.routersim.com/NetVis4_BSCI_Home.html
Loki
