It is currently Sat Feb 28, 2015 4:03 pm
 Post subject: simple question: How can i start a career with computers?
PostPosted: Sat Apr 21, 2007 11:33 pm
I really love being on my computer. I do all sorts of different things. Most of all i play my games of course, but i also spend hours learning how to do 3d animations, write in HTML and basically just fiddling with various things. So how can i turn my passion into a career? im only 20 years old and got my first computer a couple month ago. i can already take the whole thing apart and piece it back together, do various mods, and build a computer from scratch. i can also make 3d models fairly well using a free program called anim8or found at www.anim8or.com. i live in a small town were nobody has really done anything with there lives so there is nobody i can turn to for advice and help for following my passions, so please help!
PostPosted: Sun Apr 22, 2007 5:47 am
You can do whatever you want.
If you want to be a programmer, you need a degree.
If you want to fix / maintain / build PCs, you should get a certificate.
If you want to do graphic design, web programming, etc., you could go with either a degree or a certificate.
Since you know slightly more than nothing, your first task should be to figure out what you like to do ... then figure out how to turn that into employment.
PostPosted: Mon Apr 23, 2007 10:59 am
haha i like doing all those things and would be very happy with any of them.
