wow haven't been back in a while
Here is a kind of technical/troubleshooting note
So now at 20 giveaways the most recent from OCUK with something a little different
This set of data that separates OCUK from all the 20 or so groups tested by us.
In the past water cooling is usually less than 5% of the sampled results, on OCUK at this point we are 30% water cooling(marked in red), 70% air.
What made it readily obvious was the statistical cluster of 20% water in the marginal-zero-negative result category. The other 10% is mostly the H50 in the performed as expected group. Might be linked to compound mix but I have a sense that it may have an overall edge in C/P for the H50.
In any event The air cooler group (marked blue) has it over the water with pretty much positive results across the board.
