It is currently Mon May 20, 2013 1:00 am
Post new topic Reply to topic  [ 582 posts ]  Go to page Previous  1 ... 18, 19, 20, 21, 22, 23, 24 ... 30  Next
PostPosted: Thu Dec 13, 2007 6:28 am
Million Club
Million Club
Can't wait for Christmas... Hoping for a quad that I can have the fun of OC'ing to the max.
PostPosted: Sun Dec 16, 2007 1:10 am
xxxxx
PostPosted: Wed Dec 19, 2007 5:49 pm
Greetings all. I'm fairly new to this forum, but I thought I'd share my OC system specs. I don't use CPU-Z, as a rule. I prefer Everest Ultimate. Here are my rig's specs...
Antec Nine Hundred
Gigabyte S-Series GA-P35-DS3L
Intel Core 2 Quad Q6600 (B3) @ 3.0Ghz 1.35v
Zalman CNPS9700 (On Arctic Silver)
2x1GB Corsair XMS2 PC6400 DDR2 @ 667Mhz (4-4-4-12) 1.9v
PNY 8800GTS 320MB @ 600Mhz / 1760Mhz
Creative Sound Blaster SB0570 Audigy SE
Lite-On LightScribe DL-DVDRW LH-20A1M186C
150GB WD Raptor 1500AHFD-OORAR5 10,000RPM 16MB Cache
320GB WD Caviar 3200JB-OOKFA0 7800RPM 8MB Cache
Sony MPF920 Floppy Drive ('cause I'm an ol' guy)
BFG Tech BFG650PSU 650Watt Power Supply
Windows XP Professional
The thumbs show my every day clocks. Prime95 tested stable. I have had my rig running higher clocks (suicide OC for GameSpot 3DMark glory), it was configured as follows...
CPU - Intel Q6600 B3 @ 3.3Ghz (1.42v)
Memory - Corsair XMS2 PC6400 @ 734Mhz / 5-5-5-12 (1.9v)
GPU - PNY 8800GTS 320MB @ 647Mhz / 1980Mhz
I don't know how stable it was running at these clocks. I was more than a little hesitant to try a burn-in. I just checked the temps (nearing red line for B3) and ran 3DMark06. I didn't get any caps of Everest with it that high, but for proof, I offer my 3DMark06 Orb link. If you check the configuration tab, it shows my CPU frequency. Although, Futuremark never has listed my GPU frequency correctly. Sorry 'bout that. And no. I don't feel the need to repeat my suicide run, just to get Everest screen caps. LOL!!! :P
3DMark06 - 12434
PostPosted: Thu Dec 20, 2007 10:14 pm
Million Club 2+ [PC]
P4C 2.4 to 3.3
AMD X2 3800+ to 2.5
Currently running a C2Q6600 at 3.6ghz
PostPosted: Sun Dec 23, 2007 10:50 pm
Stewie Federation (2 Million)
Well right now I have my E6300 up to 3.707 GHz on air. It's stable at 3.6 but not any higher than that. I think I will get it higher when my new dry ice pot arrives :twisted:
cpuz
PostPosted: Mon Dec 24, 2007 3:48 am
Saw the dry ice, but like many others...no validation.
PostPosted: Mon Dec 24, 2007 7:07 am
Ok...I dislike the thought of being lumped into the masses with "no validation". I have no reason to falsely claim my OC results and the inference that I might be doing so is somewhat grating/off-putting. So, just for those that absolutely won't take screen caps, or a 3DMark Orb as proof of an OC, here are the much vaunted CPU-Z validation links.
My rig @ 3.0Ghz (everyday clocks)
My rig @ 3.3Ghz (suicide run)
*Repost* My Rig's Specs / Daily Clocks (to prevent scrolling up and down)
Antec Nine Hundred
PostPosted: Wed Jan 02, 2008 10:19 pm
Team Dino
Team Dino
E2160 @ 3.0 GHz
Using a GigaByte P35-DS3L board.
Not bad for a >$100 board and >$80 CPU!
n0b0dykn0ws
PostPosted: Sat Jan 05, 2008 9:51 am
(I don't use validation through CPUz, I could be full of it!)
Gaming processor is a P4 2.66 GHz (805 family dual core) running perfectly fine at 3.6 GHz (air cooled).
PostPosted: Sat Jan 05, 2008 1:37 pm
Team Member Top 250
Team Member Top 250
The 805 is a Pentium D, not a Pentium 4. Just FYI.
PostPosted: Sat Jan 05, 2008 7:17 pm
ahh, good point. Seems like Intel has kept the P4 name for ages now :lol:
PostPosted: Fri Jan 11, 2008 2:30 pm
I got my Intel Q6600 up to 3.7GHz on air cooling at 1.512 volts. It's Prime95 stable also.
CPU-Z Validation -->> Click Here<<--
CPU : Intel Core 2 Quad Q6600 (*1)
CPU Arch : 4 Cores - 4 Threads
CPU PSN : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
CPU EXT : MMX SSE SSE2 SSE3 SSSE3 EM64T
CPU Cache : L1 : 4 x 32/4 x 32 KB - L2 : 2 x 4096 KB
Core : Kentsfield (65 nm) / Revision : G0
CPUID : 6.F.B / Extended : 6.F
Freq : 3702.13 MHz (411.35 * 9)
MB Brand : EVGA
MB Model : 122-CK-NF68
NB : NVIDIA nForce 680i SLI SPP rev A2
SB : NVIDIA nForce 680i SLI MCP rev A2
RAM Size : 4096 MB
RAM Freq : 528.9 MHz
RAM Type : DDR2-SDRAM Dual Channel
RAM Ratio : 7:9
RAM Timings : 5-5-5-18
Slot 1 : 1024MB (PC2-6400)
Slot 1 Manufacturer : PDP Systems
Slot 2 : 1024MB (PC2-6400)
Slot 2 Manufacturer : PDP Systems
Slot 3 : 1024MB (PC2-6400)
Slot 3 Manufacturer : PDP Systems
Slot 4 : 1024MB (PC2-6400)
Slot 4 Manufacturer : PDP Systems
I don't dare go any higher on air cooling.
PostPosted: Fri Jan 11, 2008 2:37 pm
Team Member Top 250
Team Member Top 250
(I don't use validation through CPUz, I could be full of it!) << *FusilliJerry's Edit* Don't have the proc anymore, oh well, don't believe me then
E2140 @ 3Ghz (FSB wall above) on a DFI Blood Iron.
Despite the unfortunate FSB wall, I must say I'm 100% satisfied with it's snappiness and value.
Last edited by FusilliJerry82 on Sun Mar 09, 2008 12:41 pm, edited 2 times in total.
PostPosted: Tue Jan 15, 2008 7:11 pm
[b](I don't use validation through CPUz, I could be full of it!)[/b]
My System Prime Stable @ 3.3 max hit the wall with this VID @ 1.3250
Q6600 GO 2.4 OC'D to 3.3
Motherboard EVGA nForce 680i SLIi 122-CK-NF68-6A61ITT2C-00
BIOS 691N0P31
2 GB Corsair Dominator CM2X1024-8500C5D
EVGA 8800 GT OC'd
Cooler Master Stacker 832
Thermalright Ultra 120 Extreme with 2 Silenx 72 cfm 14db fans in push/pull
Ultra X3 1000w psu
W.D. 150gb 10K Raptor (system)
W.D. 500 gb (storage)
http://img256.imageshack.us/my.php?imag ... ocdun7.jpg][img=http://img256.imageshack.us/img256/2372/3dmark8800gt33ghzgpuocdun7.th.jpg][/url]
http://img256.imageshack.us/my.php?imag ... oltau3.jpg][img=http://img256.imageshack.us/img256/4964/33ghzprimestable145voltau3.th.jpg][/url]
http://img113.imageshack.us/my.php?image=mypcst9.jpg][img=http://img113.imageshack.us/img113/2235/mypcst9.th.jpg][/url]
http://img113.imageshack.us/my.php?image=mypc2gw0.jpg][img=http://img113.imageshack.us/img113/6872/mypc2gw0.th.jpg][/url]
PostPosted: Tue Jan 15, 2008 7:16 pm
[I don't use validation through CPUz, I could be full of it!]
OOOPPPSSS Sorry about the links try the ones below :lol:
PostPosted: Mon Jan 28, 2008 3:13 pm
C2D E6750 2.6 GHz
Cranked up to 3.2 GHz, with 3.6 stable as the highest that I tested at so far.
http://i60.photobucket.com/albums/h40/teh_r0bot/1-27-08.jpg
@ 3.2 GHz = 40c, 1600 FSB
@ 3.6 GHz = 45c, 1800 FSB
I bet i could get to 4 or beyond, but running on air right now and would like to have this pc work for a long time.
PostPosted: Mon Jan 28, 2008 10:51 pm
No. Just the Pentium. It's you guys wanting to drag the "4" along. It's been Pentium5 since the Presler/Cedarmill.
The Allendales are Pentium 6.
PostPosted: Mon Jan 28, 2008 10:52 pm
No you can't. I hold the odds, you hold the wager. What are we betting?
Print the system you're using, and try...I'll take the bet as long as you don't change the bottom line...your system. You can't do it. So don't claim the bet. People listen, so don't lie or hedget the bet.
Pinks? CPUz validation is now being called. New Sheriff is in town.
PostPosted: Wed Jan 30, 2008 5:05 pm
I'll be the witness ;)
PostPosted: Tue Feb 05, 2008 6:06 pm
I rather stick with my default clock speeds. Longer life span is what I like.
