It is currently Sat May 25, 2013 8:58 pm
 Post subject: What effect does changing AGP ratio have?
PostPosted: Fri Jul 02, 2004 10:32 am
My AGP ratio is set at 6:2:1. What effect would setting it at 7:2:1 or 8:2:1 have?
AMD 3500+
1 GB Corsair XMS PC3200
Abit AV8
Radeon 9700 Pro
Audigy 2 Platinum
PostPosted: Fri Jul 02, 2004 11:52 am
Celeron
Celeron
FSB:AGP:PCI
it would probably change your cpu's fsb or something like that.
PostPosted: Fri Jul 02, 2004 11:56 am
Professional Dork
Professional Dork
Assuming you kept the FSB the same, it would slow down your PCI and AGP bus speeds.
6:2:1 = 200:66:33
7:2:1 = 233:66:33
8:2:1 = 266:66:33
PostPosted: Fri Jul 02, 2004 1:31 pm
if you mess with AGP or PCI busses, you may screw things up.
PostPosted: Mon Jul 05, 2004 7:01 pm
or make it better. Kind of a wide spectrum we got here. If he wants to up the FSB and it's borking at some point, then he'll have to adjust that ratio to lower the AGP and PCI buss back down closer to 66/33Mhz.
Users browsing this forum: nbrowser and 3 guests
