It is currently Sat May 18, 2013 6:19 pm
 Post subject: Water cooling in a Cooler Master HAF X
PostPosted: Sun Jun 17, 2012 12:46 pm
I am planning a build and I was going to water cool the CPU for it. I was going to get a Cooler Master HAF X and I was wondering if the Corsair H80 will fit in the are for the fan on top. The space is 200mm x 30mm and the H80 is 120mm x 38mm. Even though the spot is bigger can the radiator still fit in it? If it can't are there any better solutions?
 Post subject: Re: Water cooling in a Cooler Master HAF X
PostPosted: Sun Jun 17, 2012 12:54 pm
I could be the asshole and say if you aren't doing massive overclocking, you don't need water cooling.
PostPosted: Sun Jun 17, 2012 1:09 pm
I was going to overclock and I wanted water cooling so that I could overclock farther.
