It is currently Fri May 24, 2013 12:53 pm
 Post subject: Corsair H100 - Need to know length of water lines
PostPosted: Fri Jun 15, 2012 3:50 pm
If you have a Corsair H100, could you please measure the water lines for me, or if you already know - post the lengths here?
I've got an old 2004 Silverstone case with the PSU on top.
I'd like to put a Corsair H100 at the top of the case after I cut a hole for it, but I'm not sure if the length of the water line from the radiator to the CPU block will reach the CPU on the mobo.
I've already googled my brains out on this and can't find a single reference to the length of the water lines anywhere, in any of the reviews, and including Corsair. From all the pictures I've seen of the H100, it looks like the water line is about the same length as the radiator - about 10.8 inches, which will reach if I put the fans on top of the radiator inside the case.
But I'd really like to be sure about it first, before committing to buying the H100.
Thanks for the effort in advance.
BTW, replacing the case is not an option, because I really like the way that case looks, and I'm in the process of making a few ventilation mods to it - two down, one to go. I'll be posting pics in the modding forum when I'm all done and it (hopefully) looks really sweet.
 Post subject: Re: Corsair H100 - Need to know length of water lines
PostPosted: Sat Jun 23, 2012 11:26 am
Continued googling this one...
I finally found the correct search strings to find what I wanted. And I found the answer here.
H100 tube length is approximately 35cm or 13.77in. It should fit, no problemo!
Have a Good One! :)
Rooke
Users browsing this forum: dtischerd and 0 guests
