It is currently Tue Jun 18, 2013 9:09 pm
 Post subject: thermal take cooler
PostPosted: Sat Mar 31, 2012 4:08 pm
i was wondering if this would be a good pair a thermaltake clw0211 bigwater 760 with a Intel i7 3960x cpu
 Post subject: Re: thermal take cooler
PostPosted: Sun Apr 01, 2012 3:41 pm
I would say its good if its your first time installing a water cooling loop. Otherwise I would buy individual parts and build a loop that way
PostPosted: Mon Apr 02, 2012 6:33 am
thnx for the reply thats what i was thinking as well , ive always been a bit cautious about water cooling systems and with the new rig im building i figured id give it a try. i also found on frozencpu.com a EK h30 240 ltx water cooling kit i was thinking about getting although ive never used water cooling b4 so im not sure wich exactly i should get........ the rig im building is as follows...
coolermaster haf-x nvidia edition case
either 3960x or 3930k not sure yet..
asus rampage 4 extreme
1300 watt rosewill psu
32 gbs corsair vengence 1600
120 ocz vertex ssd
1 tb WD black
gtx 580 SC going to upgrade to gtx 680 3-way sli when the new models come out!!
nzxt 5 fan touch screen controller
PostPosted: Tue Apr 03, 2012 5:19 pm
This is a better kit than the thermaltake http://www.frozencpu.com/products/11743 ... 0c321s1310 If you are looking to spend more than that buy the pieces separately because no one manufacturer makes the best components in every category.
