It is currently Wed Jun 19, 2013 6:48 pm
 Post subject: AMD cpu coolers
PostPosted: Sat Oct 01, 2011 2:09 am
I have been looking on newegg to try and find a cooler that fits my AM3+ cpu and there look to be not much out there wiether it air or all in one water cooler it does not matter to me I just want one and I'm talking about a high end model.
 Post subject: Re: AMD cpu coolers
PostPosted: Sat Oct 01, 2011 3:25 pm
A AM3 cooler should fit, AM3+ just has a different pin layout. Try a Hyper 212+, arguably the best cooler for the money.
PostPosted: Wed Nov 16, 2011 1:43 am
Be cautious of the cooler you choose. For instance, I ordered a Corsair A70 cooler for my AM3 Asus "M4*****" motherboard. The A70 would fit fine, but it will install ONLY facing up and down.
(Instead of my A70 sucking air from the front side area of the case and into the exhaust fan at the back of the case, it was sucking warm air from the below GPU and blowing it upwards into the PSU area)
PostPosted: Fri Dec 02, 2011 12:29 pm
Folding Master (Top-ranked)
There is a newer coolermaster 212 out it has larger tubes so there is no space between the tubes where they touch the cpu. It is a tall cooler I think you need a 71/2 in case. I have two 212+s and they work great. Less than 50 degrees C at 3.8.
PostPosted: Fri Dec 30, 2011 8:30 pm
I have an AMD processor that comes with the case full of fans. My room is air-conditioned and I guess the area is enough to run it for more than 12 hours a day.Image
PostPosted: Sat Dec 31, 2011 5:25 pm
when you are running folding at home even on a stock clocked cpu it gets real warm. There are several utilities available to tell what the temperature is. Like speedfan and core temp. I believe most of us are running after market HSFs.
PostPosted: Sat Dec 31, 2011 6:27 pm
yeah, only my spare desk runs stock cpu coolers. I should weld them all together and make a cool looking tower.
