It is currently Wed Jun 19, 2013 1:39 pm
 Post subject: GPU thermal paste ?
PostPosted: Tue Aug 30, 2011 8:05 am
My video card started to over heat more then usual so I decide to take it apart and dust it out. I put everything back together and it still ran hot. So im thinking new thermal paste ? does it matter what kind you use ? and do you put the thermal on the GPU and the ram or just GPU ?
Specs:
q6600 stock clock (for now)
H70 cooler 4GB ram
ocz vertex 2 100GB ssd
1TB spinpoint 3
ATI 4870
Now I know what you thinking 4870's are known to run hot yes I agree but I enabled manual fan control and is set at 60%. sitting at 49 50 c idle and goes to 60 71 when gaming is there a way to flash the card lol so it always runs at 60% idle at all times ?
Also what would be a good card to buy with the build I have ? I mostly play WoW cata and I run it at 1680 x 1050 res
 Post subject: Re: GPU thermal paste ?
PostPosted: Tue Aug 30, 2011 11:27 am
Put paste on everything that touches the heatsinks (except for the screws. If I state the obvious, I can't be blamed if someone misses it.)
PostPosted: Wed Aug 31, 2011 3:53 am
Thanks but you answered my least important question I asked . Dont worry someone else will pick up the rest.
PostPosted: Wed Aug 31, 2011 7:32 am
Ooh, now I see. You can use most kinds of CPU paste. When you replace the cooler, ALWAYS use new paste. Don't forget to clean off the old stuff. Rubbing alcohol works well.
PostPosted: Wed Aug 31, 2011 3:32 pm
I used a brand called xigmatekhttp://www.newegg.com/Product/Product.aspx?Item=N82E16835233069&Tpk=xigmatek%20pti-g4512 PTI-g4512 its what I had around. I cleaned it off well and I would have put some on the memory but there was this white block thing on the memory so I left it there
PostPosted: Wed Aug 31, 2011 11:50 pm
I cannot exactly help you because I am sold on Nvidia. I did, however re-paste my graphics card heatsink/fan. Damn, that was a beautiful looking chip!
Lowered my temps by about 3-5°C.
PostPosted: Thu Sep 01, 2011 2:49 am
Million Club - 5 Plus
on my 4850 (not 70, but should be similar layout) I used artic cooling mx2 the last time I redid it. very easy to use, made a thin "x" on the GPU. works well, but they have mx4 paste now which is better.
the RAM and VRMs have thermal pads or tape (as opposed to paste) that youll need to reuse. just take it easy peeling that stuff off as its easy to wreck, although you can tease it back into shape if youre patient.
I use 91% isopropyl alcohol (get it at the drug store for a couple bucks) and coffee filters to clean the gpu and heatsink.
PostPosted: Thu Sep 01, 2011 7:40 am
My info is for Nvidia too, but there is not much you can do to a heatsink and a fan. The EVGA ones are almost the same as a couple of the AMD coolers.
PostPosted: Thu Sep 08, 2011 3:51 pm
UPDATE Please help Sorry if this is in wrong section
so I clean card from dust re apply paste pulled up my game had it on for 5 mins screen locked up computer restarted and I had black screen. I turned it off went outside for 10 min or 15 came back still no video. I then took card out put back in make sure it was seated right in slot . still no video
I then tryed different 6 pins from my 850 tx psu nothing... I then made sure all ram slots was in alright by pulling and putting them back. I then tryed another PSU I had from a working computer . nothing .
I dont have on board nor another pci e card I can use
My board gets stuck at 26 post code. no beeps at all
system specs
evga 680i
q6600 stock 2.4
4 GB Kingston hyper x 4x1gb
corsair 850 psu and h70 cooler
Visiontek HD 4870
ocz vertex2 100gb
spinpoint 1 tb hard drive
PostPosted: Fri Sep 09, 2011 7:22 am
I bet the heat fried it. Put an ice pack on there and wait until the weather cools.
