It is currently Tue May 21, 2013 9:53 pm
 Post subject: Low temp boiling liquid immersion build
PostPosted: Sat Aug 20, 2011 12:20 am
I found this video on youtube:http://www.youtube.com/watch?v=Z_X_hgtlJpA
This is better than those oil immersion builds that were popular a while back. The only drawback is that the liquid apparently costs about $300 per gallon. Still, In a sealed system I don't know that you'd even need a full gallon. Something to think about for a future maximumpc build? Maybe even a Dream Machine?
Ok, I'm now dreaming about the extreme overclocks that you could do - without even using a heat spreader! :o
 Post subject: Re: Low temp boiling liquid immersion build
PostPosted: Sat Aug 20, 2011 7:51 am
Another recommendation for the next DMPC: Something military themed, like the Cyborg RAT7.
PostPosted: Sat Sep 03, 2011 12:10 pm
Million Club - 20 Plus
or you can put a HS on it for some ridiculous (note that it is spelled correctly) bubbling effects :D
I saw that before, and it looks great. only problem is that for a more powerful build, you will need more peltiers.
Ted
PostPosted: Sat Sep 03, 2011 7:09 pm
Ted
Who misspelled what?
Also, why oil? Why not liquid nitro?
PostPosted: Wed Sep 21, 2011 10:06 am
Ted
Oil worked pretty good too, here's the old vid: http://www.youtube.com/watch?v=PtufuXLvOok
I like the new stuff better though.
