It is currently Sat May 18, 2013 1:57 pm
 Post subject: Need a video card - budget $200-250 and system tweaks soon.
PostPosted: Thu Sep 08, 2011 9:38 am
I have two 2 x SAPPHIRE 100297-2L Radeon HD 5830 Xtreme. But are hardly used and I may sell them and get one really good card. Based on the AMD Gigabyte MB I have that can do x16x16 should I stick with an ATI/AMD Graphics card or is it ok to go with MSI N560GTX-TI Twin Frozr II/OC GeForce GTX 560 Ti (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card (Maximum PC's best of the best item).
Or should I just Crossfire what I have?
Also, after I sell my old system I can make tweaks to this one if you have any helpful ideas.
Thanks!!
My System:
1 x Seagate Barracuda ST31000524AS 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
1 x CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ16GX3M4A1600C9
1 x ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
1 x COOLER MASTER Hyper TX3 RR-910-HTX3-G1 "Heatpipe Direct Contact" 92mm CPU Cooler
1 x Microsoft Windows 7 Home Premium SP1 64-bit - OEM
1 x AMD Phenom II X6 1090T Black Edition Thuban 3.2GHz Socket AM3 125W Six-Core Desktop Processor HDT90ZFBGRBOX
1 x GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
1 x NZXT GAMMA Classic Series GAMA-001BK Black Steel ATX Mid Tower Computer Case
2 x SAPPHIRE 100297-2L Radeon HD 5830 Xtreme 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
1 x COOLER MASTER GX Series RS750-ACAAE3-US 750W ATX12V v2.31 SLI Ready 80 PLUS BRONZE Certified Active PFC Power Supply
 Post subject: Re: Need a video card - budget $200-250 and system tweaks so
PostPosted: Fri Sep 09, 2011 1:06 am
Team Member*
Team Member*
The 5830s in xfire would be similar in performance to one 560ti if that helps at all.
PostPosted: Fri Sep 09, 2011 11:11 am
That does help. No sense in selling the two cards I have if they will perform about the same as the better model.
